GTX 780 upgrade?
Is it worth to upgrade from a gtx 670 to a 780?
i have a guy selling his for about 200bucks USD, and im wondering if i should go for it.
Im just doing 1080p gaming, and plan to stick with it for awhile.
For $200 it's not a bad price for a 780, but with Nvidia nerfing the Gtx 700 series through driver support I wouldn't feel comfortable personally buying into it. I would wait till tomorrow and AMD's launch of there R9 300 cards. Those might cause the R9 290 and 290x under $200 on ebay.
good to hear, i did not know about the amd launches. thanks
sounds like deals since I'm pretty sure I paid double that if not more for mine lol, personally I like my 780
Right now you can get a new R9 290 which is faster than a 780 for $240
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202143&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
After the new launches though prices may fall.
so should i pass it up?
The $200 780? Yeah probably.
Yea the 780, okay ill just wait to hear from the new 300 series from AMD. and hope the 290 will drop in price
Yeah I'd probably sell the 670 and put it towards a 290 - grab one before the (re) launch of the 3xx series. <$250 at most retailers. Not taking anything away from the 780's though but being 2nd hand there will be limited warranty remaining.
