I've been planning to upgrade my PC for about a year now. As the prices went down I went from planning to buy a 680 to a 780 now, but I still was wondering what variant of the gtx780 I should get. I'm mainly concerned with noise and then power, in that order. Also I'll give the total specs of the PC I'm planning:
I7 4770k w/ a Noctua NH-D14 attached
gtx780
ASUS Sabertooth z87
1866MHz Corsair Vengeance Pro 16gb (2x8)
WD black 1TB
Samsung 840 EVO 120gb
Corsair RM850
Fractal Define R4
They are both good but I would rather have evga backing such an expensive card.
I believe the Asus is a tad quieter though.
I hear the DCUII cards are excellent, but from personal experience, I currently am running an EVGA 780 ACX, I can tell you they are fantastic cards.
Pick whichever one you think looks the best ascetically. The coolers are very similar in performance.
I just had to RMA my EVGA 780 ACX classified the other day thanks to Newegg sending me a open package product. Had a horrible oscillating/rattling sound. Hopefully my new one doesn't have those issues as well. I did get a chance to play with it a bit and I love the dual bios aspect of it. If you get the 780 classified and you want to overclock make sure to change to the second bios, seems to overclock better. I had it running at 1.2ghz rock stable.
As someone has owned cards from both ASUS and EVGA and currentl;y own a GTX 780 ACX Classified. Get the classified. The direct CU II is good but its not as good as the ACX, The classified has an added thermal mass and is amazing. Definatly Classified over Direct CU II
