GTX 770 bottleneck with i7 920 CPU?
I'm contemplating a GTX 760 or 770 to upgrade my rig, but I'm not sure if a 770 would be a better choice considering its going to be paired with my older i7 920 CPU. I, of course, do want to also get a 500GB SSD, as well as maybe more ram and a heat sink for my CPU to OC, since I'm using stock. As for the display, I do intend to upgrade once the G-Sync enabled-monitors come out next year, so a GPU upgrade would be prudent.
CPU: Intel® Core™ i7 CPU 920 @ 2.67GHz
GRAPHICS CARD: NVIDIA GeForce GTX 460 768mg
MOTHERBOARD: EVGA X58 SLI LGA1366
RAM: OCZ Gold 6GB (3 x 2GB) 240-Pin DDR3 1066
DISPLAY: SyncMaster 2233SB,SyncMaster Magic CX2233SB(Digital) 1920 x 1080
HDD: Western Digital WD VelociRaptor 10000 RPM 300gb
OPERATING SYSTEM: Windows 7 64 bit
PSU: Corsair 750TX
give that i7 a little OC and go for the 770 I would say the first gen i7 is still a respectable cpu
