(GIGABYTE) GeForce GTX 770 OC 4GB : http://www.memoryexpress.com/Products/MX45834
VS
(EV3A) GeForce GTX 770 Superclocked 2GB: http://www.memoryexpress.com/Products/MX46144
Which one?
VS
Which one?
I'd say the 2GB unless you're running on more than 1080p resolution. If you plan on going multi-monitor or a >1080p resolution I'd go with the 4GB.
4GB is better cuz moar gigabytes yo. Future proof noh' what i'm saying'. No, just get what you you can afford/ willing to pay for. I'd get the 4GB and so, the superclocked version does not make so much of a difference in fps
Wait so with the superclocked 2GB I'd get higher Fps? or the other way around?
Personaly I would go with the 4GB version if I (you) could afford it. As games and their texture files get bigger, and higher quiality, you will notice the difference.
Yeah, in the long haul 4GB is going to be better, as for price it's going to be steep though.
It looks like within the next couple years 1440p+ res monitors are going to become pretty standard. For only $60 more, I'd definitely get double the memory. But if you don't have the cash the 2gb version will serve you pretty well too.
