Dear Logan,
Can my gtx 760 run three shimian 2k monitors?
From,
Nickco43
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130944
Dear Logan,
From,
Nickco43
Not Logan, in games using all three monitors it might be a bit of a stretch,
Three 2k monitors is 6,912,000 pixels
One 1440p monitors is 3.7 million pixels, Logan did a benchmark video in the asus card, so that could help you see where it would stand (Link:http://www.youtube.com/watch?v=GvAmOlSSU-8)
You would have some trouble gaming on high/ultra settings, but I don't see why it wouldn't support three monitors.
If you're gaming then you could look into a shimian 1440p display and a 770, but it's your choice, I hoped this helped and good luck!
