Hi, I was wondering which is better, two ASUS GTX 760's in SLI or two MSI Twin Frozr GTX 760's in SLI? I'll be running triple or quadruple monitors. Thanks
Hm i think one higher end card for around the same price would be better there are a few problems with SLI and can be a pain to get working
Personally, I'd go with the Asus cards - they're both aesthetically pleasing and perform great. I've got two Asus GTX 660TI's in SLI with three monitors and they perform great - but they are limited to a smaller frame buffer and VRAM allocations.
EVGA 4gs OC 670 SLI. Go big or go home. If you're are on a budge Asus makes 670 4g which something to think about becuase 4 monitors is hella on the ram consumption.
What about two MSI Twin Frozr GTX 760 4GB in SLI?
Do you plan to play high end games on the monitors? if that's the case i'd get one single high end card and then another if you need it. Something like a 7970 or 680/770
