my overclock using GTX 760 gigabyte windforce edition and valley benchmark, any opinions, advice, or comments?
looks good what volts you running that oc on? you may be able to get the core clock up a bit more if you up dem volts and pull back the memory oc a little.
running stable at stock voltage
