Hey guys. So I have had this MSI GTX 680 TWIN FROZR II for almost a year now. This was a problem that I had sorta fixed, and with no real way of knowing, but the problem is back and even more annoying.
I am currently sitting here and the GPU temp is currently 30c. The fan speed is set at the lowest 30%. The Fan RPM...2,400. It will idle between that and 3,000. Sometimes reaching max speeds of 5,000. I have tested it and it does not change based on the GPU usage or temperature.
I am trying to find a fix for this. I would rather not have to send it to RMA. Because well I don't have another graphics card to just slap in there and wait. MSI's customer service stinks, so I am hoping people of the community can help me out.
I have updated drivers, change drivers, uninstall drivers, use the stupid MSI afterburner. I had the Corsair fan controller, and it won't listen to it. I have even reseated the card. Something to note, because I got pissed of at it...I smacked the card and it dropped from 4,000 to 2,500.... Not a good sign I know. I really want this card to work. I never get the card to go past 60c and I want it to run quietly. My PC sits right next to me due to my room size. If possible I'd like it's max to be 2,500 RPM. I have all my other fans sitting at a nice quiet 700-1400 RPM, so it's very very obvious when it's going.
Thank you for any guidance in advance,
-Zerume
