Gtx 670 power edition benchmarks
I keep getting an error on imgur >.>
my score: 15198
hardware: 14923
Physics test: 717
Fur test: 820
fluid test: 1151
Raymarch test: 755
Loading time: 11632
Ill benchmark some games too if I can figure out which benchmarking software does that free.
I get roughly 35-55 fps in metro (over the course of a few missions, never dropped below 30, max was 110 in some places)
I get a constant 60fps in a heavily modded skyrim (although not as modded as logans I dont think, ill have to find out what mods he used) with some lag spikes very rarely (I assume its world loading).
This is my first graphics card and damn everything looks amazing, before I was playing 768 not 1080 on every game and my setting were always moderately low or medium (as I was using i5 3570k hd4000) now I can play everything maxed out.
Im interested in seeing your benchmarks too guys (preferably on catzilla so they are easier to compare)
Card overclocked quickly in msi afterburner (ill try and do some more precise overclocks to find the max stable soon)
Power limit : 90% Core clock: +75Mhz Memory clock: +150mhz Fan speed 75% (god these fans are loud, is there a way to make it so they arent constantly on 75% >.> without having to mae them constantly lower?)
I have a EVGA Reference GTX 670 that I will totally post benchmarks for here in a few days. I am letting my new thermal paste settle in before I push it. I once had it running around 1200 Mhz Core with a 6258 memory, I think I got lucky with my card. Right now with 30% fan the temps are hovering at 40c, which seems to be the lowest it wants to go. Amazing card, and which benchmark are you using?
About the fans, you should grab MSI Afterburner, if you don't already have it, and just set the fan curve lower at the temp you usually see for ingame performance.
What are you using to bench and at what settings ?
If im bored ill probably bench my Oc'd 7950 to see how it matches up.
I am going to bench with 3d mark, 3d mark 11, and vantage. EVGA's mod standards. Oh! and Catzilla. It's to comical to deny.
@Beyond I used the free version of catzilla to benchmark.
