Should I spend the extra money and get a 660? Or is the 650 ti boost good enough? I want to play on resolution 1920x1080. I like ultra but I do not mind turning it down to high.
The 650 Ti boost is almost as good as the 660 but, I don't think you'll need to get the 660 for that. On a side note, for around the same price you can get the hd 7870, which outperforms both
wiliam is right. Srsly the 7870 and I believe 7850 outperfroms 660ti in every newest game. Like 10-20%
amd has been doing some driver wiazardy recently, effectivley rendering old benches unreliable
thanks guys, which 7870 is best?
7870XT from sapphire
