I wanted to get an ASUS gtx 660 cause their cooling is amazing, but the FTW edition is 30 dollars cheaper. Should i get the FTW?My pc is as follows: http://pcpartpicker.com/p/2XO7o (couldn't actually find the FTW on there)
My experience with 660s is that they don't get very warm to begin with. So unless you're planning a beefy overclock, go with the cheaper card.
All depends on what you want to do really. The ASUS GTX 660 should do a better job at maintaining a cool temperature when overclocked but the FTW should be quieter because it has only 1 fan.
If this is the card you are talking about
