Hi guys,
Just got home from college and I'm messing around with my other machine and I'm attempting to overclock the GPU with little success.
The card in an EVGA 650Ti SSC. It is factory overclocked to 1072 Mhz so I wan't expecting to get much, but I can't get anything.
Using EVGA Precision X and Afterburner if I raise the GPU clock or memory clock a reasonable amount, say 25-100 Mhz on the GPU clock nothing happens. In game it goes up to 1072 Mhz and stops. Never going over despite the slider setting. GPU-Z says that the clock is whatever I raised it to, but on the sensors page it reports only going up to 1072 Mhz. FRAPS is also reporting no gain in FPS when I benchmark it at the stock speed and then at the overclock. Nothing. Not even half an FPS. They are identical.
Then though if I raise it a crazy amount, say to 1300 Mhz, it actually goes up to that speed with that speed being reported by Precision X and GPU-Z in the sensor panel. However, within about 15 seconds of playing a game it freezes and the driver crashes.
Not a thermal problem either, card never gets above 50C
I'm not really looking to get a huge boost in performance, my Dad primarily uses this computer but some would be nice and more I'm just curious as to why moderate overclocks don't work. Never had this issue with any other GPU.
Machine specs: HP Pavillion something or other, nVidia nForce? AM3 mobo, AMD Athlon II X4 630 @ 2.8Ghz, 16GB of Kingston HyperX Blu RAM, Samsung 840 Evo and a WD 1TB Caviar Green. Then of course the EVGA GTX 650 Ti SSC. Using the newest drivers.
(I also tried this in my 8 Core machine and got the same thing happening)
Any help would be appreciated. Like I said, not really caring if I get a stable OC just curious as to why this is happening.
