GTX 570 temps
I just recently bought an MSI GTX 570, it's the one with 1 fan. It's about 2 years old.
My idle temperature is ~44C and load is ~92C. If I put the fans to 85% I get about 85C on load.
What can I do to get the temps lower? Should I replace the thermal paste?
That would help, also clean out any dust from the heatsink, it is a 2 year old card after all.
Can you guide me in a direction for replacing the thermalpaste? I've never done it before
Those are pretty high for sure.  You have to take off the cooler completely, scrub the existing thermal paste off with rubbing alcohol and toilet paper.  Dont apply too much pressure when doing this.  Then apply the new thermal paste in a pea shaped dot.  Remember, less is more.  Not sure as to how large that gpu is, so i cant really say how much.  Anywho, put all screws back into cooler, plug into computer, enjoy!
