Hello
I got a GTX 560 Ti in SLI and I've recently realized that one of my cards don't run at fullload (hovers around 70% load) while benchmarking, gaming etc. And even weridier, that card runs hotter...
I got a 750W powersupply so I don't think it's the powersupply's problem. I have the most recent drivers (that's I've reinstalled twice) and the problem sustains at various clock speed?
Is this a serious issue? Should I dismiss it? Anyone else experience similar things? And is there a fix for this?
If your fps is okay and it doesnt bother you then I wouldnt panic, if it does then maybe invest in a higher wattage psu
I've just noticed that the one GPU is throttling... but I don't understand why it's throttling when the temps aren't even past 80C...
Is this still a PSU problem?
Have you overclocked the card?
If you have try going back to the stock clock and see if it has stopped
you can try activating k-boost through percision x, that way the clock speeds on your cards are left at the highest level, should improve benchmarking some what.
Does your motherboard properly support two GPUs?
(Make sure the 2nd PCIe slot isn't x1 when running two cards)
