Gtx 560 or Radeon 6870
Forget about price. Which one is better for battle field, minecraft and most games. THanks You decide.
Well the GTX 560 is supposed to be about the same as a GTX 460, and a GTX 460 pretty much exactly the same as a Radeon HD 6850.
That being said, I would go with the 6870.
ok thanks
if minecraft and OpenGL games in general are what you want performance in, then Nvidia is where its at, ATI/AMD has shit support for it and a 9800GTX+ could render minecraft better than a 5850, I know this from experience and research
if you want a solid number for minecraft with a 128*128 texture pack your looking at running about 200-300 frames a second average with a 560.
Dude, any card on the market can run minecraft.
yeah they can run it, its just nvidia runs it better
If you decide to get 6870, (which would be the best choice to go with) there is a sale at newegg currently for $130 - after $30 MIR.
Use coupon code EMCYTZT1567
I live in Canada. So if you can get some codes for newegg.ca it would help me.
