ok i have a system with a Q6600, evga 750i mobo, 4gb of 1066mhrz ram, and i want to get a gtx 295 and have a 9800gtx+. and i was wondering if there will be a bottle neck with a new gtx 295.
pretty sure there will be.. can u just give me the 295 instead :D
what will cause the bottleneck?
cpu
if i overclock will it help of should i just get a new i7 cpu
overclock your q6600
sure it will help but i reckon still be bottle neck, and if you can afford a i7 why the heck not
how much will the bottleneck effect game play... like wat percent
over 9000
i gained 10fps in crysis from e8400 to q9550
but still think im getin a bottleneck
i get 40avrg fps at 1400 x 950 res
and get 40fps with 16 aa
weird huh
its all going to depend on how far you can get your q6600.
>nvidia chipset
good luck overclocking.
so wat would the ideal prosessor for me to get... a new quad core or dual core?
>dual core
I believe you're at the wrong year. 2006 is that way.
Just overclock your Q6600 and you'll be fine. What cooler have you got?
ultracombo wrote 1 minute ago »
>dual core
umm... lol i have stock cooler
cyberpandaninja wrote 40 seconds ago »
>dual core
lol
dude get the i7
then a new graphics card
the 300 series is gona be so crazy just wait for that trust me
ok so am i just fuked or how much will i get effected by not doing any thing... like how much performace will i lose
cyberpandaninja wrote 3 minutes ago »
>dual core
You might want to invest in a good cooler as well. May I recommend the V8? It's a little expensive, but it's a great cooler. You can also find other coolers for a better price, though personally I use the V8 and it's great.
>dual core
how far do u think i could overclock with the v8. and would ocing my ram do anything??
