Gtx 260 core 216 sc problems
I got this card on December 14th
IT plays most of my games fine except for a couple those being
Gta iv
Crysis
and some others
in all those games i get way under the benchmarks some times be 40 fps somes time by 20
I have overclocked my cpu to 2.9ghz and nothing i do seems to work this these games
Especially Gta iv, it plays at 10 fps with updated drivers and everything
Is it my os? i get weird codes before the load screen, i cant read them they load to fast.
OS
vista 64bit
Specs
P5n-d 750i
Q6600
2gb ocz sli 800mhz
500gb WD
Protip: Record video of load screen. Watch video. pause at wierd codes.
Also, a lot of benchmarks are done with high-end Q9xxxs/i7s and 4+GB of RAM. I wouldn't worry too much.
Yea i understand that but the performance i am getting in comparison with theirs way lower
And? I have an exact same setup as MeGotRice when he did his 9800GTX+ benchmarking. He had 680i LT mobo, 4gb RAM, etc. But he had a Q66 and his benchmarks were like 20-30Fps above mine on an E7200
Protip: GTA IV runs shit no matter specs.
yea dude, GTX 295 cant run GTA 4 for shit lol, try more stable games
yea ok i really wanted to get into gta..the story was supposed to be good
>GTA
>Story
lawl.
I just play GTA to kill whores.
Yeah me too... I just use cheats and go rage
why do you have 64 bit os. It's really only useful if you have 4 GB or more of ddr. that might be your problem. if it is just go buy 2 more GB like [url=http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3089875&CatId=2264]THIS KIND[/url]
I'm using the same kind works great overclocks well.
64 bit is just pure pwn.
yeah but it won't do nottin if you don't have 4 GB or more otherwise it's useless. I use 64 bit but I'm useing 6GB
Plus Who doesn't like using cheats and killing everyone. Also keep the resolution down low or it runs shit.
GreenSLi wrote 2 hours ago »
Close your eyes, I have a surprise for you..
GreenSLi wrote 4 hours ago »
good times, good times..
I change the language settings of the enemy to Korean and start laughing. Lol.
OH YOU DIDNT! lol
>2GB 800mhz
There's your problem. System resources take up 35% and your game takes up %60
Get more RUM
MeGotRice wrote 5 hours ago »
>2GB 800mhz
Get more RUM
Yeh, 2GB is phail nowadays, u need at least 4+ GB.
hmm he is right.
When my Vista is "Idle" (Firefox open etc) It is using 38% RAM... And I KNOW what I have on my pc lol, im not running a bunch of crap in the background.
I am suprised that I have had this pc for so long (may 2008) and still havnt formatted it yet ^^ I dont want to install all those games and programs back on..
