Having trouble deciding what to do. Keep my current build and swap the gpu for a gtx 1080.
CPU Intel Core i5-4670K 3.4GHz Quad-Core Processor
CPU Cooler NZXT Kraken X61 106.1 CFM Liquid CPU Cooler
Motherboard ASRock Z97E-ITX/ac Mini ITX LGA1150 Motherboard
Memory Kingston HyperX Fury Blue 8GB (2 x 4GB) DDR3-1866 Memory
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive
Storage: Western Digital Caviar Green 3TB 3.5" 5400RPM Internal Hard Drive
Video Card: XFX Radeon R9 390X 8GB Video Card
Case: NZXT Manta (White/Black) Mini ITX Desktop Case
Power Supply Corsair RMx 650W 80+ Gold Certified Fully-Modular ATX Power Supply
Or get a 1070 and upgrade to something better
CPU Intel Core i7-4790K 4.0GHz Quad-Core
Motherboard MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard
Memory Kingston HyperX Fury White 32GB (4 x 8GB) DDR3-1866 Memory
Video Card: GTX 1070
Case: ENTHOO EVOLV ATX GLASS
Help xD
Just wondering,
what games do you typically play?
The Division, Black Ops 3, Fallout 4, Mad Max, Counter Strike, Doom (New one), Mirror's Edge, GTA V.
At what resolution too? as a 390x is still very good for 1080 max or high end 1440p
Really? Because I get stuttering and dips in 1080p gaming that I have to lower the settings
Really? I have the lower version currently r9 390 (non x) and I play AAA titles at 60+ fps in 1440p maxed out, including
GTA V 50-65fps 1440p maxed w/ 2x scaling (no AA)
Tomb Raider 60fps 1440p with hairworks Maxed
Are you sure you have r9 390x not 380x?
i would personaly just upgrade the gpu firstly.
About the GTX1070 vs 1080, since we dont have seen any performance compairissons between both gpu´s.
We cannot realy say how well the GTX1070 does in compairisson to its bigger brother, since the GTX1070 isnt out yet.
Absolutely sure. The pricetag was not one of a 380 xD Also reasoning for upgrading the processor was video rendering >.<
Fair enough xD
Weird as I have no issues personally, but I also have 5820k so whether that is helping me in my particular games
if your going to upgrade and change over to nvida 980TI all the way. the 1080 is a joke in its reference form aka founders edition. in my eyes its the 290x launch all over again.
if i had the money burning a hole in my pocket i would tell my self to chill and wait on polaris 10 or vega/navi before buying this time around. nvida released first with a paper launch because there scared as hell at the moment. so lets see what made them scared before we buy.i know i will plus you will be upset when the 1080TI launches and gives you buyers remorse.
Do you already have a 4k or 1440p 144hz display?
you have some issue somewhere if your 390X can't max games at 1080p, and if you only have a 1080p display upgrading your GPU would be pointless.
Just save your money for an X99 based system if you do a lot of video work
