Yeah, I had to set the speed in my BIOS so it is running at 3200MHz. And oof, running Heaven at 1080p Extreme gave me a 1616, which from what I’ve seen is not a good score at all.
Also, I’m an imbecile and my GPU power cable wasn’t fully inserted, but strangely that didn’t seem to effect anything whatsoever.
sorry should have had a comma in there. what i mean is the gpu isnt the problem something else is. windows/cpu/mobo/ram/psu probably in that order of likeliness too.
@nassau I had similar issues when I switched from my 980 ti to the a 1080 ti for me it was the bios version of my Mainboard I did a update and windows fresh install and it fixed it for me .
I didn’t understand however why it ran fine with 980ti and not with the 1080ti
Maybe you can go a easy route and use ddu uninstaller and delete the nvidia driver and install it again because that didn’t work for me when I tried
set performance settings under windows to ryzen balanced and gpu performance to maximum power like in the screenshot above this post @MazeFrame posted after maybe this helps
