I wanted to try Ubuntu, so I installed it on an empty Samsung Evo 250 GB ssd I had just bought. After playing around with it for a couple of months I wanted to return to windows 10. Since I had my new Samsung ssd I wanted to reinstall windows on that disk instead of using my older disk with windows already on it (regular mechanical harddrive).
Since then i have been using windows 10 without problems for about 3 months. Then the other day I bought a new 2 TB seagate barracuda for more storage. Now when I start my computer it enters grub "rescue mode".
I've read on a bunch of forums and tried "set prefix" and all that stuff, but nothing seems to work...
When I type "ls" I get:
(hd0) (hd0,msdos1) (hd1) (hd2) (hd2,msdos1)
I don't understand if this is remains from Ubuntu or something with windows. I'm sort of a noob when it comes to this. What should I do to boot in to windows again?
I had once weird problem that it decided to be just data drive and I couldnt figure out how would one change it back NTFS, so I ended up installing the whole thing again
Cant help you but you could check if file system is what it should be
