Green mean machine
I am planning a build with the FX8320 and Crossfire R9 290s. Here is the challenge to this build. It must look green. I want a green themed computer build with the lights and the sorts. I don't got any ideas how to pull it off which it was I am asking you guys to help me. You guys helped me many times before. I want to see what you come up with this time. The price I am setting is $2500 and I want lots of SSD storage. Also I want the FX8320 and R9 290s as cool as possible.
i was playing arround with your color scheme, its not easy matching lol.
i came up with this: http://pcpartpicker.com/p/pBM2bv
picture of the case, stolen somewhere on the net!
I will come with an amd version in a minute.
AMD: http://pcpartpicker.com/p/MJhdrH
maybe you could chance the mobo for the sabertooth if you like.
Grtz Angel ☺
What i would do is use one of MisteryAngels build and then cool it with a water loop and green fluid. What you would do is get transparent tube 9and waterblocks if wanted) and then use a green fluid. I can come up with a parts list if you want ?
Also if you have never tried wc'ing then you could get someone else who has experience in your area or you could give it a go yourself.
You could also re sleeve the PSU cables so they are green as well.
