A quick question, I’m using my 1080Ti as a pass-through device on a windows VM. But one other reason I bought the 1080Ti is to use it for machine learning. Is there a way to use the GPU for this application. Because the way I understand it, the device itself is blacklisted for normal use. Is there a way to initialize the GPU after the system boots up?
Or would it be better to have a different vm (linux based) and use the same pass-trough method to use the GPU on a linux based system for ML.
What are your thoughts on this?
