Hello guys , which of these 2 graphicards is better ?
http://www.eprice.it/schede-video-SAPPHIRE/d-4708407
http://www.eprice.it/schede-video-SAPPHIRE/d-4766822
THANKS,
THANKS,
Only one of your links worked.
If you want a 7870, hop on the bandwagon and get a 7870 xt/tahiti le. They have the same gpu as a 7950, and they're a lot cheaper. They're excellent cards.
Oh sorry about that ! Hers the second link http://www.eprice.it/schede-video-SAPPHIRE/d-4766822
That is a question I honestly cannot answer as I am not sure what you want to do with the cards. As far as the specs go here is a comparison I did with Newegg and hopefully it can answer the questions you have about both of these cards.
GET THE XT!!!!!!!!!!!!!!!!!
110% get the XT
