Graphics Card under $150
Hey guys I was just wondering if you know any decent graphics cards under 150 on partpicker. I live In aus so they have to fit my budget.  :)
Many Thanks
                    -Bluey
How much are the HD 7770 and the gtx 650ti where you live?
If you are not paying $200 or more for a graphics card you more than likley are not going to get good price per performance but If its that strict of a budget then heres a reccomendation
http://pcpartpicker.com/ca/p/qo37
Hope it helped!
depends on which brands
Thanks
the 7850 that I linked will smoke a 650ti and a 7770 but may cost more in your region but it is also under $150
Which brand do you recommend ?
Xfx is good and use a stock pcb but if you want the max overclocks msi with their twin frozor coolers are amazing but cost way over your budget.
Would this be good? Asus radeon HD 7750 1gb video card
Yes asus is a great manufacturer and the 7750 is a decent card but if you can get a 7770 or 7850 then go for it!
Any card under the $200 mark is a waste of your money as far as gaming goes.
in some cases but the 7850 I linked before would be a great gaming card for the $150
Thanks WaffleTime :)
I agree with waffletime the 7770 and 7850 are very good cards for the money and what rollymaster said is simply not true I have a 6870 that I got for $170 and I play all my games on high settings at 1080p with 40+ fps.  The 6870 is somewhere between 7770 and 7850 in terms of performace for reference.
Would the power colour 7770 be good?
its a very basic card but is a 7770 so should be good for decent settings @ 1080p
Thanks
A 7770 or 650 Ti. If you can find a 7850 than that will be better.
What about the Gigabyte GeForce GTX 650 ti 1gb?
