Graphics card decisions
Should I go with a Radeon HD 7770 Ghz edition or a Geforce Gtx 650ti. They are both similar in price but I have no idea which performs better. Thanks for helping me out and in a month or two I'll be a member of the PC gaming world!
between those two the 650ti is better but try and get a HD7850
Depends on where you are buying it, the 650 ti might cost more. If you check out online you'll see that the 650 ti has a better performance. I had a 7770 in my first build computer and I quickly change it for a 7850 and it was a better value for the money.
The 650 Ti is faster, but like the others of said if you can afford it go for a 7850 or a 650 Ti BOOST as they're quite a bit faster.
https://www.youtube.com/watch?v=TkVolu3wXbs
 You can get a HD7790 for around the same money as a GTX 650TI and its a lot better.
http://www.anandtech.com/bench/product/776?vs=781
