Graphics card advice
Looking for advice on the best gpu around 200 that can handle crysis 3.
Thanks.
search new egg.com and put your limit at 200 then pick anything that has at least 2gb of memory and over 900hz clock.
ASUS R9 270X              259.99      http://www.newegg.com/Product/Product.aspx?Item=N82E16814121802
MSI GTX 760                 249.99      http://www.newegg.com/Product/Product.aspx?Item=N82E16814127745
EVGA GTX 660             209.99      http://www.newegg.com/Product/Product.aspx?Item=N82E16814130825
I picked a few options just incase your price range can flex a little.
Thanks much :)
 Think i am going to try out
Get an R7 270.  A 270X is a stupid factory overclocked overpriced POS.
that 270x costs more than a 760, a noticeably better card
