Graphic card
Much appreciated if I get recomendations for a graphic card
My PC Specification is AMD 8350 CPU
750 WATT PSU
ASUS 990FX MOTHERBOARD SABERTOOTH R2.0
Also my budget is $140 £120 max
In addition I dont mind cross firing
What are you going to be doing with the computer?
(CrossFire or SLI won't be a viable option at £120)
Powerful Gaming and Video Editing
Your not going to get anything overly powerfull for £120 you can pick up HD7850's or GTX650TI boost cards for that.
Willing to go to £135
These are the olny 2 cards i can find in that price range better than the 7850/650tiboost
http://www.amazon.co.uk/Sapphire-11199-16-20G-Graphics-Display-Express/dp/B00A1572TQ/ref=sr_1_1?ie=UTF8&qid=1383152933&sr=8-1&keywords=hd+7870
Or
http://bit.ly/1ctnZxg
Save up another 15 quid and get a HIS Radeon R9 270X IceQ X2 Boost 2048MB
I'm with you on this one. Just got one of these myself and overclocked to 1175/1450 without touching the power. Only ever goes up to 62°C without making much noise, and that's in a Fractal Define R4 with gimped airflow.
If you're going to be gaming with a 150 quid budget, this is a good choice.
