Graphic card compatibility
Hey guys,
I want to install a new GPU in an HP compaq dc 5800 small form factor, but it seems to have smaller pci ports on the back. (I don't know how to call them).
An nvidia gtx 740 will be enough. Will this fit ???
http://www.palit.biz/palit/vgapro.php?id=2318
Thanks
If it comes with a Low-Profile Bracket, yes it will. I don't think this model comes with one though.
How can I find one that comes with one?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487095
http://www.newegg.com/Product/Product.aspx?Item=9SIA24G2U47126
http://www.newegg.com/Product/Product.aspx?Item=N82E16814500340
http://www.newegg.com/Product/Product.aspx?Item=N82E16814500337
these all have low profile brackets is just a matter if u want DDR3 or GDDR5 and 1 or 2 GB of vram, u could also get a low profile 750/750ti if it fits ur budget
here are some
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127836
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125677
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125680
