My question of the day is - is there some “rule” about the default output port of a GPU?
Not long ago I started my quest for that TV as a second monitor. All went well until I realized that my MSI 2080 Ti Gaming Trio has only one HDMI (occupied by the monitor), and 3 DisplayPorts (and this is after my 15m expensive HDMI cable arrived).
So I ordered a DP->HDMI adapter. All went well (again) and I was able to connect both the TV and Monitor. But one thing I completely missed out on - the “default/main” monitor. The one, to which BIOS and stuff is shown on every boot.
My first (well, let’s assume I firstly googled for a few hours to see if this can be configured) idea was to simply switch places both the hdmi cables (one direct and one through the adapter). And that seemingly worked.
But I’m now looking at the switched cables (and they differ quite enough to know which is which), and see that after a few reboots BIOS is once again shown on the TV. If to look in nVidia’s settings (and Windows’ “share screen” thinghy, they both now recognize the monitor as “1”, instead of “2”).
Although this is something, to which I can get used to, it’s now more of an “interesting thing” than a necessity.
Having similar issues with my dual-monitor setup after switching from an AMD GPU to Nvidia. Also switched from W10 to W11, but I can’t remember if I switched GPU before or after switching the OS. Pretty sure I used the AMD card with W11 before I got the new GPU but not 100% sure.
I figured it was just that my secondary monitor woke up faster (secondary may be TN or VA while main monitor is IPS), but seems similar to your issue.
Was no problem on my 5600XT. Main monitor was always ‘1’ everywhere but now my secondary is ‘1’. Tried switching ports on the GPU to no avail.
Only occasionally will I get the BIOS on the second monitor, but sometimes windows will think it’s the main monitor on boot. Second monitor is vertical so it’s quite annoying.
Like you said, minor inconvenience but still quite annoying.
Ahhh yes, One of the key differences between monitors and TVs, and one of the main drawbacks of using a TV as a computer display.
You may want to turn it off frequently depending on what panel type it is. I know OLEDs are prone to burn-in but if it’s not receiving any signal all the pixels should just be off I guess? Not sure if it would be an issue or not.
Still could be something going on software-wise. But it’s beyond me at that point.
Reasonable. But if I’m not mistaking, the “power” button on the remote does turn off the display part (but I do think everything else moves to standby). Think this would still be treated as “display is on” from the board perspective. Guess it’s a dead end unless I fully power down the tv.
