GPU uprage (GTX 780) Help
I want to update my current GPU (AMD HD 7850) to a EVGA GTX 780 SC can i do it without a bottleneck and does it even fit on my case
SPECS:
RAM: 8GB
PSU: 700W COOLER MASTER
CPU: i5 3570k 3.4ghz
CASE: CiT Vantage Midi Mesh Gaming Case
MOTHERBOARD: ASUS Z77-V LX
Thanks :)!
Thats a pretty solid quadcore cpu, so it would work fine, no bottlenecks there.
see the case manufacturers website, the lengte of that graphicscard you can find on the evga website.
No bottlenecks. That processor is still very competitive with the new I5's and AMD stuff. Just make sure you uninstall the old AMD drivers before you install the new 780.
