Is there any way to test if your GPU is working properly?
How so? As in right after you've installed it? Or do you believe it's under-performing or something?
run a benchmark program and compare your results to others with your card. If the score is drastically different they there may be a problem.
I'm just wondering if it might be underpreforming, how would one know?
