GPU Temps
I have a gigabyte 7790 2gb OC and i went into the amd overdrive center and maxed the speed out and put fan to 100%
at idle i get 36 degrees and at load i get 50 to 55 degrees is this to high or am i fine?
You're fine :)
Thnx :) now i can play and not worry.
