So I have 2 Sapphire 390x's
The top card isn't spin the fans until it reaches 96C then turns them back off when it get to 94C
I'm unsure what is causing this?
I have just reinstalled windows and the Drivers and the problem has just appeared.
I doesn't happen each time i boot the system as well.
Where to I start?
Did it start after you reinstalled?
try downloading the cards software and changing the fan settings so that it spins up at 36C and is max speed by 72C
Have you messed with max temps in Radeon Settings? You could also set a custom fan curve in something like MSi Afterburner.
Yes i happened when I reinstalled Windows and the drivers.
TriXX has been a pain for the fan curves and WatMan has been working quite well.
Maybe Watercool all the Things
I have a Sapphire Tri-x Fury, and I never use TriXX. I just use afterburner. WattMan is pretty good though.
