GPU Temp Questions
Hey everyone I have a ASUS HD7870-DC2-2GD5-V2 in my system and i want to play around with the clock speeds but I don't know what the max operational temp for the card is, If anyone could provide me with this info that would be great.
the max is 95c I think is when it will throttle and maybe turn the computer off not sure.  When you are overclocking a video card I like to keep the temps under 75c. overclock it then play with the fan curve in msi afterburner or what ever program you are using and find a good balance between clock speed and fan noise.  I use unigine heaven to do the fan tuning as its a realistic load.  For testing stability use MSI kombustor and unigine heaven
Okay thanks! I so far have it under 55c.
yeah, you can crank it up a bit from there. I have my 2 660s running at 1.2ghz and they get to about 75c in unigine.
