GPU sag on my pc after my upgrade
H
how would one fix gpu sag on a build? My old gpu is about the same weight but it stayed even. Do I have to fabricate a bracket? I'm not much of a modder as far as hardware.
You can usually find a bracket for your particular card.
seems like a lot of people just put stuff under it. I'm gonna try to find a peice of acrylic to make into a feature cause I don't want it to look gheto.
Just make sure it doesn't act as an insulator as you don't want heat being trapped due to whatever mod you'll be doing.
But of course. ;)
