Hey, I have an 8350, asus sabertooth and I am about to upgrade to something like an asus 760 direct cu ii oc or an asus r9 280x is my 650 watt corsair enthousiast series (tx650) psu going to be enough?or am i going to have to upgrade that to
yes, it should be fine you could run 2 770s on that, gpu manufacturers overestimate the power requirements just so the gpu has alot of overhead, you should really be fine with any gpu with that wattage.
