got a 7950 and a sabertooth r2 with 8320
x16 slot keeps turning tne monotor off
x8 slot works perfect
card very big seems to drop slightly on one side when case is upright
lay on its side runs ok
why would the 16x slot be doing this any help please
possible dud? i've never had this problem, my 7950 does not tilt at all, it's perfectly straight,
try using th e two 6 or 8 pin connectors and run them up above the card and give it some tension? maybe to keep the card straight or screw in both pci bracket screws if you have not done so
+1 for mrflufffypants. its most likely screws
