GPU Passthrough Virtual Machine Manager
The guest virtual machine is not receiving a signal to it's monitor when turning on the Virtual Machine if it's physical GPU or it's physical sound are assigned to it. Please help? :blue_heart:
The host's monitor seems to freeze or perhaps it's just the inputs that are freezing like the keyboard and mouse being switched to the VM, however that does not occur unless the passthrough GPU or it's sound is assigned to the Virtual Machine.
Checklist:
1. CPU supports VT-x, VT-d, ACS & EPT.
2. Motherboard supports VT-d.
3. Passthrough GPU supports UEFI.
4. The two GPU's are not identical, both are different generations, and both are NVidia.
5. The guest monitor is plugged into the GPU that will be passed through and it is turned on and set to display through said cable
6. The GPU as well as the monitor that will be assigned to the guest are not damaged in any way and if the GPU Passthrough works, they should be functioning properly.
7. VT-d is turned on in the bios.
8. CPU: "virtualization extensions available"
9. IOMMU is turned on. [ 0.000000] DMAR: IOMMU enabled [ 10.892650] DMAR: Intel(R) Virtualization Technology for Directed I/O
11. The devices I'm trying to pass through support resetting.
12. The PCI groups are valid.
13. These are installed: qemu-kvm, seabios, qemu-utils, hugepages, bridge-utils & ovmf.
14. Testing unbinding the PCI Stub from the Passthrough GPU through the terminal works properly and does not freeze the host monitor or inputs.
15. The GPU that will be passed through as well as it's High Definition Audio Controller are claimed by PCI Stub. "claimed by stub"
16. I created the /etc/modprobe.d/kvm_iommu.conf with: options kvm allow_unsafe_assigned_interrupts=1
17. The guest OS installs and run fine when using the host's GPU & monitor.
18. I don't see any errors from virt-manager.
19. I removed the default: spice server & it's associated GPU, spice channel, CD-ROM Device, Sound, Serial, VIrtio Serial, USB Directors and tablet from the virt manager setup..
20. KVM hidden state, is turned on in the xml of the VM:
<features>
<acpi/>
<apic/>
<kvm>
  <hidden state='on'/>
 </kvm>
</features>
<cpu mode='host-passthrough'/>
<clock offset='localtime'>
<timer name='rtc' tickpolicy='catchup'/>
<timer name='pit' tickpolicy='delay'/>
<timer name='hpet' present='no'/>
</clock>
    'QEMU/KVM Connection Details'
    TBD
     'Virtual Machine Manager Settings:'
    Overview:
    Hypervisor Details:
    Hypervisor: KVM
    Architecture: x86_64
    Emulator: /usr/bin/kvm-spice
    Firmware: UEFI x86_64: /usr/share/OVMF/OVMF_CODE.fd
    Chipset: i440FX
    CPUs:
    CPUs:
    Local host CPUs: 12
    Current Allocation: 8
    Maximum Allocation: 8
    Configuration:
    Model: host-passthrough
    Memory:
    Memory:
    Total host memory: 16010 MiB
    Current allocation: 7096
    Maximum allocation: 7096 MiB
    Boot Options:
    Boot device order:
    IDE Disk 1
    IDE Disk 1:
    Virtual Disk:
    Advanced Options:
    Disk Bus: IDE
    Storage Format: raw
    Mouse:
    Virtual Input Device:
    Type: Generic PS2 Mouse
    Mode: Relative Movement
    '(Not able to be removed as the button is greyed out)'
    Keyboard:
    Type: Generic PS2 Keyboard
    PCI '(My PCI address here)':
    Physical PCI Device:
    Device: '(My GPU and its address here)'
    ROM BAR: Checked
    Device: '(My GPUs High Definition Audio Controller and its address here)'
    ROM BAR: Checked
    Controller USB:
    Type: USB
    Model: USB 2
    Controller PCI:
    Type: PCI
    Model: pci-root
    Controller IDE:
    Controller:
    Type: IDE
I'm going to try to get you some help by giving a shout out to @mythicalcreature , @SgtAwesomesauce , @wendell maybe one of them will see your post and chime in.
This may be a card that doesn't support reinitialized. Power down the machine and try fresh making sure nothing initializes the card to be booted. If that doesn't work boot windows on bare metal and use gpu-z to dump the card rom then specify to use that rom in your VM
It's possible, but usually when I have issues with unsupported cards (the modern AMD ones, that is) they give me a corrupt display and the VM doesn't properly boot.
@Miri can you list your hardware and give a bit more info about the system you're using? Specifically, what GPU's you have and which is being passed through? CPU and motherboard are also of interest in this situation.
I followed this guide with no luck on fedora 27. I know my pc supports passthrough because I did it before with Ubuntu 16.04
Thank you for your submission, but this thread has been dead for 11 months. Typically, we create a new thread in this situation. If youโ€™d like to create a new thread, Iโ€™d be happy to give you a hand.
Also, this isnโ€™t exactly a guide, but a help thread.
