When I pull lspci it appears that my onboard audio, and USB controllers share drivers with the Nvidia GPU audio, and then the USB card I have to pass through to my VM.
00:00.0 Host bridge [0600]: Intel Corporation Skylake Host Bridge/DRAM Registers [8086:191f] (rev 07)
Subsystem: Micro-Star International Co., Ltd. [MSI] Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Host Bridge/DRAM Registers [1462:7998]
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
Kernel driver in use: skl_uncore
00:01.0 PCI bridge [0604]: Intel Corporation Skylake PCIe Controller (x16) [8086:1901] (rev 07) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 16
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: de000000-df0fffff
Prefetchable memory behind bridge: 00000000c0000000-00000000d1ffffff
Kernel driver in use: pcieport
00:01.1 PCI bridge [0604]: Intel Corporation Skylake PCIe Controller (x8) [8086:1905] (rev 07) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: df100000-df2fffff
00:02.0 VGA compatible controller [0300]: Intel Corporation HD Graphics 530 [8086:1912] (rev 06) (prog-if 00 [VGA controller])
Subsystem: Micro-Star International Co., Ltd. [MSI] HD Graphics 530 [1462:7998]
Flags: bus master, fast devsel, latency 0, IRQ 151
Memory at dd000000 (64-bit, non-prefetchable) [size=16M]
Memory at b0000000 (64-bit, prefetchable) [size=256M]
I/O ports at f000 [size=64]
[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
Kernel driver in use: i915
Kernel modules: i915
00:08.0 System peripheral [0880]: Intel Corporation Skylake Gaussian Mixture Model [8086:1911]
Subsystem: Micro-Star International Co., Ltd. [MSI] Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th Gen Core Processor Gaussian Mixture Model [1462:7998]
Flags: fast devsel, IRQ 11
Memory at df652000 (64-bit, non-prefetchable) [disabled] [size=4K]
00:14.0 USB controller [0c03]: Intel Corporation Sunrise Point-H USB 3.0 xHCI Controller [8086:a12f] (rev 31) (prog-if 30 [XHCI])
Subsystem: Micro-Star International Co., Ltd. [MSI] Sunrise Point-H USB 3.0 xHCI Controller [1462:7998]
Flags: bus master, medium devsel, latency 0, IRQ 122
Memory at df630000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
00:14.2 Signal processing controller [1180]: Intel Corporation Sunrise Point-H Thermal subsystem [8086:a131] (rev 31)
Subsystem: Micro-Star International Co., Ltd. [MSI] Sunrise Point-H Thermal subsystem [1462:7998]
Flags: fast devsel, IRQ 18
Memory at df651000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: intel_pch_thermal
Kernel modules: intel_pch_thermal
00:15.0 Signal processing controller [1180]: Intel Corporation Sunrise Point-H Serial IO I2C Controller #0 [8086:a160] (rev 31)
Subsystem: Micro-Star International Co., Ltd. [MSI] Sunrise Point-H Serial IO I2C Controller [1462:7998]
Memory at df650000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
00:15.1 Signal processing controller [1180]: Intel Corporation Sunrise Point-H Serial IO I2C Controller #1 [8086:a161] (rev 31)
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at df64f000 (64-bit, non-prefetchable) [size=4K]
00:16.0 Communication controller [0780]: Intel Corporation Sunrise Point-H CSME HECI #1 [8086:a13a] (rev 31)
Subsystem: Micro-Star International Co., Ltd. [MSI] Sunrise Point-H CSME HECI [1462:7998]
Flags: bus master, fast devsel, latency 0, IRQ 153
Memory at df64e000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: mei_me
Kernel modules: mei_me
00:17.0 SATA controller [0106]: Intel Corporation Sunrise Point-H SATA controller [AHCI mode] [8086:a102] (rev 31) (prog-if 01 [AHCI 1.0])
Subsystem: Micro-Star International Co., Ltd. [MSI] Sunrise Point-H SATA controller [AHCI mode] [1462:7998]
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 139
Memory at df648000 (32-bit, non-prefetchable) [size=8K]
Memory at df64d000 (32-bit, non-prefetchable) [size=256]
I/O ports at f090 [size=8]
I/O ports at f080 [size=4]
I/O ports at f060 [size=32]
Memory at df64c000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
Kernel modules: ahci
00:1c.0 PCI bridge [0604]: Intel Corporation Sunrise Point-H PCI Express Root Port #1 [8086:a110] (rev f1) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
Memory behind bridge: df500000-df5fffff
00:1c.2 PCI bridge [0604]: Intel Corporation Sunrise Point-H PCI Express Root Port #3 [8086:a112] (rev f1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 18
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
Memory behind bridge: df400000-df4fffff
00:1d.0 PCI bridge [0604]: Intel Corporation Sunrise Point-H PCI Express Root Port #9 [8086:a118] (rev f1) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
I/O behind bridge: 0000c000-0000cfff
Memory behind bridge: df300000-df3fffff
00:1e.0 Signal processing controller [1180]: Intel Corporation Sunrise Point-H Serial IO UART #0 [8086:a127] (rev 31)
Subsystem: Micro-Star International Co., Ltd. [MSI] Sunrise Point-H Serial IO UART [1462:7998]
Flags: bus master, fast devsel, latency 0, IRQ 20
Memory at df64b000 (64-bit, non-prefetchable) [size=4K]
00:1f.0 ISA bridge [0601]: Intel Corporation Sunrise Point-H LPC Controller [8086:a149] (rev 31)
Subsystem: Micro-Star International Co., Ltd. [MSI] Sunrise Point-H LPC Controller [1462:7998]
00:1f.2 Memory controller [0580]: Intel Corporation Sunrise Point-H PMC [8086:a121] (rev 31)
Subsystem: Micro-Star International Co., Ltd. [MSI] Sunrise Point-H PMC [1462:7998]
Memory at df644000 (32-bit, non-prefetchable) [size=16K]
00:1f.3 Audio device [0403]: Intel Corporation Sunrise Point-H HD Audio [8086:a170] (rev 31)
Subsystem: Micro-Star International Co., Ltd. [MSI] Sunrise Point-H HD Audio [1462:f998]
Flags: bus master, fast devsel, latency 32, IRQ 154
Memory at df640000 (64-bit, non-prefetchable) [size=16K]
Memory at df620000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:1f.4 SMBus [0c05]: Intel Corporation Sunrise Point-H SMBus [8086:a123] (rev 31)
Subsystem: Micro-Star International Co., Ltd. [MSI] Sunrise Point-H SMBus [1462:7998]
Flags: medium devsel, IRQ 11
Memory at df64a000 (64-bit, non-prefetchable) [size=256]
I/O ports at f040 [size=32]
Kernel modules: i2c_i801
00:1f.6 Ethernet controller [0200]: Intel Corporation Ethernet Connection (2) I219-V [8086:15b8] (rev 31)
Subsystem: Micro-Star International Co., Ltd. [MSI] Ethernet Connection (2) I219-V [1462:7998]
Flags: bus master, fast devsel, latency 0, IRQ 140
Memory at df600000 (32-bit, non-prefetchable) [size=128K]
Kernel driver in use: e1000e
Kernel modules: e1000e
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP104 [GeForce GTX 1070] [10de:1b81] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Micro-Star International Co., Ltd. [MSI] GP104 [GeForce GTX 1070] [1462:3302]
Flags: bus master, fast devsel, latency 0, IRQ 152
Memory at de000000 (32-bit, non-prefetchable) [size=16M]
Memory at c0000000 (64-bit, prefetchable) [size=256M]
Memory at d0000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000 [size=128]
Expansion ROM at df000000 [disabled] [size=512K]
Kernel driver in use: nouveau
Kernel modules: nvidiafb, nouveau
01:00.1 Audio device [0403]: NVIDIA Corporation GP104 High Definition Audio Controller [10de:10f0] (rev a1)
Subsystem: Micro-Star International Co., Ltd. [MSI] GP104 High Definition Audio Controller [1462:3302]
Memory at df080000 (32-bit, non-prefetchable) [size=16K]
02:00.0 Serial Attached SCSI controller [0107]: LSI Logic / Symbios Logic SAS2008 PCI-Express Fusion-MPT SAS-2 [Falcon] [1000:0072] (rev 03)
Subsystem: Dell 6Gbps SAS HBA Adapter [1028:1f1c]
I/O ports at d000 [size=256]
Memory at df240000 (64-bit, non-prefetchable) [size=64K]
Memory at df200000 (64-bit, non-prefetchable) [size=256K]
Expansion ROM at df100000 [disabled] [size=1M]
Kernel driver in use: mpt3sas
Kernel modules: mpt3sas
03:00.0 USB controller [0c03]: ASMedia Technology Inc. ASM1142 USB 3.1 Host Controller [1b21:1242] (prog-if 30 [XHCI])
Subsystem: Micro-Star International Co., Ltd. [MSI] ASM1142 USB 3.1 Host Controller [1462:7998]
Memory at df500000 (64-bit, non-prefetchable) [size=32K]
04:00.0 USB controller [0c03]: Renesas Technology Corp. uPD720201 USB 3.0 Host Controller [1912:0014] (rev 03) (prog-if 30 [XHCI])
Memory at df400000 (64-bit, non-prefetchable) [size=8K]
05:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd NVMe SSD Controller SM951/PM951 [144d:a802] (rev 01) (prog-if 02 [NVM Express])
Subsystem: Samsung Electronics Co Ltd NVMe SSD Controller SM951/PM951 [144d:a801]
Flags: bus master, fast devsel, latency 0, IRQ 16, NUMA node 0
Memory at df310000 (64-bit, non-prefetchable) [size=16K]
I/O ports at c000 [size=256]
Expansion ROM at df300000 [disabled] [size=64K]
Kernel driver in use: nvme
Kernel modules: nvme
