The iGPU is acting up on me, and I have no Idea what to do now.
If I should reinstall the computer again, and go from there.
When I did a passthrough with the RX6700XT, I went into the bios and changed the primary GPU to the iGPU, later on I changed back to the main GPU, and when the computer wouldn’t start I changed back to the iGPU, but instead of forced, I changed it to Auto, I might need to force it again. OR! I just rewrite the hooks, do a mix between the Mudahar and Masterfighterr.
(VIDEO) MASTERFIGHTERR HOOKS
[NEXT IS PASTEBIN LINKS]
- /etc/libvirt/hooks/qemu.d/vm-name/prepare/begin
- /etc/libvirt/hooks/qemu.d/vm-name/release/end
1. » vm-vars.conf
QEMU - XML EDITING
(VIDEO) SOMEORDINARYGAMER HOOKS
» start.sh
1. » kvm.conf
(MY) QEMU Overview XML’s
Do not use these if you don’t know what you are doing!
Since you have to delete some of the stuff, it’s just there to show the combined file.
» Console Commands
So why have I been linking all of this? Well, because I kind of need some help here. I need to disect the hooks, and combine them, in the best possible way, in order to when I start the VM grab the GPU, and not like it WAS… I hadn’t really set it up right though. "/ I say it in a presens because I deleted my two prior machines in order to make a new, now that I have actually learned something from the last two machines.
IS THERE ANYBODY OUT THERE?
MAJOR TOM TO GROUND CONTROL! HUSTON WE GOT A PROBLEM!
