So I want to make the switch from Windows 10 to Linux, but I would like to still run my windows install in a virtual machine. Thing is I know absolutely nothing about GPU pass through and the like. I have a few spare old gpus, but I don’t want either of my os’s to use them when I’m using that os. Is it possible just to switch to a weak GPU for Linux and pass through my Rx 480 when gaming and stuff. Also I only have one keyboard and mouse along with one monitor. All help is appreciated
If you mean swapping the 480 back and forth between host and guest, Its not currently doable AFAIK.
Also, not to downplay the idea, but how is your linux knowledge? Passthrough is probably not the first thing I would task a new linux user with… Dual booting is a tried and true method. I would recommend another HDD and that you use your BIOS to switch between each os instead of letting grub handle both.
Excuse me if you are actually well versed in linux, I mean well.
I’ve messed around with dual booting a bit, with grub though. I just was hoping to find a one boot solution
