Firstly, apologies if this is the wrong section - I will gladly post elsewhere if it is more relevant.
Well, long story short, my laptop (Sony VAIO VPCSB16FG) has Integrated Graphics and a Dedicated GPU (AMD Radeon HD 6470M) which you should be able to switch between. That doesn't work because it cannot detect the GPU (although one program does detect the GPU, the other doesn't nor does Device Manager). I've installed drivers from multiple sites, mirrors and links multiple times followed by full restarts but to no avail. It used to work, I think, but it's been a long time and I've only just recently had the chance to address this issue.
Please let me know if there are any suggestions or if you require any additional information and I'll be happy to comply.
I've attached an image for starters, hopefully it will help. http://i.imgur.com/9ovp1CC.png
I was going to use DDU for a clean start on the drivers, but since I've never done it before (and don't want to stuff something up), I wanted to check with someone else more knowledgeable first.
The error message occurs when I try to open it from my start menu, despite it being already running and in my taskbar/tray icon, and as you can see the only one it lets me select is the Intel 3000 HD. I tried reinstalling it, but got an error that wasn't helpful. I'll give it another shot.
13.12 seemed like the right one? The site is harder to navigate than it should be. I keep getting "installation package failure" though and it just accomplishes nothing and gives no details besides it was an error during the installation.
i wouldnt go with the lastest beta version, the note seems to indicate that they are not compatible with dual graphics switching laptop.
i would uninstall both graphic driver intel and amd and do a clean install with driver fusion. get the drivers from sony site and not directly from amd or intel.
otherwise i would back-up and reset it back to factory setting. (last resort ) i usually toy around a long time (days) before taking that option.
Yeah, I was going to uninstall the drivers with the DDU and and redownload them. Do I also need to grab the registry installations too from the Sony site? Is there anything else required besides cleaning them and reinstalling?
