- I think I have a unique problem. I modified my RTX A 5000 graphics card with a RAIJINTEK MORPHEUS 8057 cooler. With the stock cooler I was always up against tj-max. Now with the modded cooler it reaches 47C with a hot spot temp of 57.6C under full load. Changing the cooler was the best over clock I could have done. I gained 1000 points in time spy with that mod alone, even for being a professional gpu. But the fans on auto stay at 400 rpm’s. The GPU doesn’t get hot enough to ramp up the fans. The problem is the ddr 6 memory will jump to 95c under load on that fan profile. If I lock the 2 120 mm fans to 1950 rpm’s the memory won’t exceed 70c under full load. Is there a way to adjust the fan profile on memory temperature rather than die temps? I use my system for cad work and some light gaming, Star Wars Squadrons, ect. I’m happy with my setup except for this issue. Here are my spec’s. I have ,
AMD Ryzen 9 5900X 12-core, 24-Thread
Msi x570 tomahawk WiFi
2x TEAMGROUP T-Force Dark Za (Alpha) 32GB Kit (2x16GB) DDR4 3600MHz total 64GB
Samsung 970 EVO Plus SSD 500GB - M.2 NVMe boot drive
Samsung 860 EVO SSD 1Tb sata 3
Pny RTX A5000
Evga 850 bq power supply
Noctua nh-d15 cpu cooler
phanteks p600s case
Case is maxed out in 140 fans
MSI (Optix MAG27CQ) 144 Hz
And a 60 Hz 55 in. TV for specific use.
