How does this work? Is it just a rough estimate of how much pixel data it can push out?
If I get a RX 580 GTS Black Edition which claims a max resolution of 4096×2160, would it be unable to run a wider/shorter display mode which has fewer overall pixels?
I need to support 5120×1440, which is just over 7 mill pixels. The “max resolution” specified (4096×2160) is almost 9 million.
That resolution is per display, so if that resolution is running from multiple outputs on the gpu then it will work, but if it from a single connector then idk.
