So, is it possible that my GPU's killing my WiFi Card? They're pretty close together (less than an inch, maybe less than a cm, I forget), but I'm not sure if that's the issue. Over the last couple weeks/months I've noticed that when I get online, sometimes it's as if someone's eating bandwidth.
The last couple days, the card's been giving me hell just to get a network connection. I used to be able to see atleast 3 other networks in the area, but it takes way too long for it t...o connect to either of the two (there's really three, but only one device allowed on it) networks. My phone shows three other networks, but the card only shows one additional (beyond my two) and not constantly (like the phone does).
I had to put the card in a farther away spot than what it was before I got the new GPU in May. The GPU is in the top x16 PCIE slot, but the Wifi now sits in the bottom of the three x1 PCIE slots. If I understand PCIE correctly, then what I Don't want to do is to put the Wifi card into either the x8 or x4 slots as that'll affect the GPU's performance.
Here's the related hardware:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128545
http://www.newegg.com/Product/Product.aspx?Item=N82E16833704133
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130948
The main hardware is only a couple years old, but the GPU was nabbed in May.
Note: the Wifi is actually on the 5GHz band while the other visible networks appear to still be on the 2.4GHz band. And I'm two months past the 2yr warranty, crap. Good thing it's only $40 if I order a new one.
Today, of course, it got on fine, but I'm still only seeing Our networks (which have hidden BSIDs).
