GPU is going under water!
Here's a pic of the expansion slot cover after I had to use a dremel to cut the screw heads off.
And here's what it looked like after I painted the expansion slot cover matte black to hide the scars from the demel.
This is how the loop looks now (GPU, CPU, & NB are a watercooled). I'm getting a new reservoir within the next coupel of weeks which will solve the kinking issue you see underneath the current reservoir.
As for the color of the fluid...I don't really like it. Under UV CCFLs it glows intensely, but I'm more than likley going to switch back to using straight distilled water with clear tubing. IMO, distilled plus clear tubing looks better than any other color combination.Â
Yup, I agree.
 Clear tubes is porn.
Looks good tho!
Here's a pic of the loop all lit up at night.
It loooks kewl, but doesnt fit to rest of case. Would fitwith my old greensli case : 3
