Received a GTX 280 waterblock used today.  The seller sent me pics of it before I bought and it was pretty tarnished. So I coated it in ketchup and polished her up.  This is what she looks like after an hour of ketchup massaging. What do you think?
Alcohol doesn't do the job nearly as well. Â Ketchup stinky? Â I'll forgive the ketchup hatred since you're not American ..though before this I did consider you my brother from a different (Norwegian) mother...but no more Green...you have been disowned.
Mother eff' BFG. Â 2 screws are friggin' stripped and it's preventing me from installing this waterblock. Â Nothing a dremel and a drill can't handle . Â Pics will be up later of the destruction!
yeah me too... awful. And alcohol does the job well. Well rubbing alcohol that is, don't start pouring jack daniels on it.. lol
Or paint remover, reaaaally strong shit, do not inhale if you don't wanna feel like you just ate 9000 bad mushrooms. Same as isopropanol. Also, it dries out your fingers : 3 no biggie.
