hi all, iv got 2 gpus at the moment in my pc, Hd radeon 6450 and a gtx 295, the 295 will not work by it self for some reason, if its only the 295 when im booting no disply is given, but if i use the 6450 i get picture in my first monitor (6450) and when the home screen comes up i get extended desktop using my 295, the 6450 is showing as the "master card" how do i make it so only my 295 is working, i dont mind only using one screen, please note i cannot use the dvi ports on the 295, they dont seem to work (il look into fixing that if i get the 295 working properly) i have the latest drivers for both, the 295 is in the first pci-e slot the 6450 in the other
also i can get both to work off the 6450 no problem
if you need any more information please ask
this is driving me crazy
thank you
shane
