GPU help? Difference of these two cards?
msi 7950 be VS msi 7950
$280 VS $200
The BE is Boost Edition. Boost allows the card to dynamically adjust the clock speed above the base clock, if temps, power consumption, and load permit. Personally, I'd save the $80, and OC the 7950 to around 920 - 940Mhz or even further - that should get your very similar results to the BE's 960MHz Boost.
