Hello Tek Syndicate community, i have to say i really appreciate the help from this awesome forum.
So, in recent days I've been looking for any options on used gpus on ebay or amazon, and i have some potential choices but i would like to know any suggestions for that specific usage i said in the title. This is my first gaming rig and looking at how much fps or in what settings some gpus get on games makes the decision very complicated.
The main goal is to play the most of modern games and maybe some old as well with good frame rates either on medium or if it's possible on high settings with good fps. Now the problem here is the budget, i have a very limited money for the gpu like about $100-$110 or $120 if i can save a little bit.
I have as an option the GTX 660 Ti or GTX 750 Ti, but i don't know how well perform under those settings on most games, any other suggestions or feedback are welcome :)
Yes... Used last gen card for 100-150$ will be faster... But 460 is brand new. And compared to the other brand new cards for the price it does well enough. This is:
480 for 250$? You can probably get 980 for less second hand and it will outperform...
On ebay the cheapest GTX 960 i can found is like $140 :/ As for the gtx 950, i can found it more near in my budget. Do you have any other suggestions from the used market?
I know having Async will be a plus for future games but anyway i just want a card i can have for a while meanwhile i keep upgrading the other components.
@Streetguru Well i think the best gpu i could go for my budget could be the GTX 960 if i can find a cheap one on ebay or amazon. I would try to look for a R9 380 too.
@NetBandit But at the moment i don't plan maxing out graphics,so for the settings i want to play i think with 2gb will get the job done but even if i can find a 4gb gpu on the cheap well that's a bonus.
